adjusting valves
adjusting valves
what is the sequence for adjusting and what gap do you recomend for the arizona desert .0018 or .0015 and is it the same int & exh oh yeah its a 66 l60 4.0 I6
- Been thanked: 1 time
adjusting valves
If you place CYL 1 at TDC, the following valves (from front to back) can be adjusted without turning the engine: 1, 2, 3, 6, 8, 9 With CYL 6 at TDC: 4, 5, 7, 10, 11, 12 Gap is .15 - .16 - intake and exhaust. Desert or snow country doesn't make a difference.
adjusting valves
THANKS IWENT IN A SIMILAR ORDER 1,5 3,6 2,4 AT .0015 STARTING AT TDC WITH CYL 1&5 TURN HALF ROTATION DID CYL 3&6 BACK TO TDC FOR CYL 2&4 MAKING SURE VALVES , IN & EXH WERE FULLY CLOSED PRIOR TO ADJUSTING. A OLD FRIEND SAID THIS WOULD WORK ,DOES IT SOUND RIGHT OR SHOULD I REDO IT ENGINE SEEMS TO RUN MUCH BETTER
adjusting valves
I'm not sure that your method fits falls in with the method above. I personally always recheck them after I drive it a bit. I can usually tell if I messed one up by a miss or ticking sounds.
adjusting valves
as always your wisdom prevails my way worked, but yours was difinetly a smother idle
