Gasket set
Locked
Gasket set
Post by npca-laporteohv »
I am in need of a gasket set for my 69 Patrol. I noticed in the Parts Web Links section that they show the gasket set for the P40 engine as being 90% compatible with our engine. Has anyone used this gasket set and will the head,valve,intake and exhaust gaskets work on our engine.
Gasket set
Post by npca-abuelo442 »
Buy the gasket set with confidence. For the job intended, the gasket set is a perfect match. The differences between a P40 and a P engine gasket set, are for the timing gear cover gaskets, and the water pump that are totally different, and easily done. In my case, I've used the P40 gasket set a couple of times. For the timing gear cover, I've used silicone and no gasket. Not a problem.   The head and manifold gaskets are exactly the same.
Gasket set
Thanks for the help...i ordered one this morning...
Locked
