Rear Brake play?
Locked
Rear Brake play?
Post by npca-stryder2000441 »
Are the rear brakes suppose to move left and right 1/4 inch or so? Never noticed this before.
Been thanked: 1 time
Rear Brake play?
Post by npca-riverpatrol »
Yes.
Rear Brake play?
Succinct.  I like that.  Thanks.
Rear Brake play?
Sorry for the brevity.They are a 'floating' type brake system. That's why the wheel cylinders are held on with several spring clips instead of being bolted on like the fronts. I think the intent is to give it better braking when backing up, since the brake shoes can shift to give more surface contact on the drum.
Locked
