That's the best part, because you'll document your mistakes AND the corrections.faux40 wrote: ↑Tue Jul 30, 2024 11:21 amDoesn't mean I'll get it right! Well, at least not the first time... because I do it right because I do it twice!RiverPatrol wrote: ↑Tue Jul 30, 2024 9:50 am It will be interesting watching you put the 5 speed in. I don't think anyone has documented that yet.![]()
1967 Family Patrol Project
- Has thanked: 7721 times
- Has thanked: 646 times
- Been thanked: 1149 times
And so it begins -- I learn stuff all the time!
This is with the transmission just barely in place -- the studs aren't long enough to extend out to have some threads for a bolt to start on Notice the bolt in the pinch between trans and bell housing -- that's the bolt that secures the shaft the 2wd/4wd & Hi/Lo shifters will reside -- there is a recess in the trans for that bolt to hide in. But, that means you cannot get to it at all without backing the trans up about 1/2" from the bell housing. There's its little cubby hole! The trans binds at about 3/8" from fully in. I assumed that this binding was thick paint and cruft, so I'll use the bolts to draw it in Well, there we go! A bolt on each side and one nut on the lower side of the trans. This is where it will ultimately reside. Once fully installed, I went to rotate the trans shaft (it's in 4th gear (1:1) -- Nope. No rotation at all. Not sure why. It rotated fine before... Hmmm It's a toss up...
If you look on top of the throwout bearing sleeve on the front bearing cover, you can see where the bell housing "shaved" the top back to fit. My guess is that what was causing the binding Does anyone know of a service manual for the marks? Or, perhaps what transmission the innards are from? I'd like to remove the front bearing cover (above), the top cover and rear cover for cleaning and inspection... but I'm hesitant to just guess. Transmissions, much like differentials, are magic inside... and I don't wanna let that magic out!
So, what did I learn that I should record so I don't have to go through this again?
- Is it binding inside the pilot bearing? That bearing had plenty of clearance before being installed, but there's really no way to check it without inserting the trans (I don't have a spare input shaft).
- OR, is the input shaft jammed in the bushing and forcing the input shaft back INTO the transmission? Seems unlikely, but I suspect possible
- OR, is the trans non-concentric with the crank?
- Test fit the trans to the bell housing BEFORE fitting it to the engine. Just to the bell housing -- not the engine. There are many possible tight points when mating the trans and bell -- Bolt alignment & diameter, the cut out in the bell housing that allows the front bearing cover/seal/throwout bearing sleeve to nest.
- Don't install the pilot bearing into the crank until after dry fitting the trans to the engine/bell housing. This way, you'll know if the trans goes into the engine
- With the Marks, you will need to have the shaft for the 2wd/4wd & Hi/Lo levers in place and tight before fully installing the transmission as it blocks access to the bolt once tightened down (I think that's the one further back)
- Has thanked: 173 times
- Been thanked: 306 times
I have just had my Marks 5 speed gearbox rebuilt. It took about 6 months. Currently sitting on the floor waiting till I have time to install it.
I plan to put a bit or a write-up about the process including some part nos etc on tis forum.
However I'm going away tomorrow for about a week, so I'll try and do it on my return.
Just by the way, have you mated up your transfer case with the gearbox? I think there is a 'special' output shaft in the transfer case.
Peter
Peter
Not sure if I will get there.
Not sure if I will get back.
But I usually do!!!
But I usually do!!!
I don't know if you have this document, it states that the gears are from a Nissan truck but doesn't specify. I recall hearing once that they were from a Nissan Junior.
I have -- well, hopefully have -- that special output shaft.Peter60 wrote: ↑Wed Jul 31, 2024 7:23 am faux40
Peter
Looking forward to the write up!
j
Brief writeup here https://60patrol.com/forum/viewtopic. ... 35#p53335
But I usually do!!!
But I usually do!!!
Been thinkin'... Caution!… long post
It all started with one Patrol, the ’67 Soft Top, the plan was to get it running as a family… That’s where the thread name “Family Patrol” started back in July 2013. Then I soon discovered the parts situation. You know you are in trouble with the parts guy at the Nissan dealer is stumped and “What vehicle did you say? Hmmm, haven’t heard of that one”
Then I found a package deal for TWO more Patrols – Grabbed the for parts, but it turned out that one was even closer to running than our first. Here they are arriving at the house from their previous home in the little town of Washington California
Then I stumbled on a steal for a fourth Patrol! Barritt and I drove to Magalia in the hills above Paradise to check it out
My plans morphed as the fleet grew… Three kids, three running patrols! Yea! Perfect! Easy enough. I mean, how hard can it be?
The kids helped removing and reinstalling the engine
We focused on Aerogirl – the ’67 hardtop from the second batch of patrols. After almost exactly one year of work, we took Aerogirl for the first drive on August 3, 2014… Literally 10 years ago last week. The kids were still small. A trip to the gas station then a trip to 31 flavors ice cream! They LOVED IT and not just because ice cream was involved! Always an adventure!
For the next four years, we drove the Patrol to all sorts of local places – To ice cream (over and over), to Folsom Lake, to the store, to the drive in! Joe even got to drive it once he had his license. Three years and two months after its first drive, Joe was driving it when the brakes failed, and he bonked a tree. Luckily, he was on our residential street at a fairly low speed… He wasn’t hurt, the tree was fine, but the Patrol took a pretty big hit. Zero brakes will do that to you! And, by zero, I mean ZERO! Gotta love single circuit brake systems…
Still having visions of three, or at least two, running Patrols, I decided to not only repair the crash damage, but to rebuild Aerogirl completely from the ground up. And the big project got bigger…
I've been working on restoring and getting Aerogirl back on the road since it crashed in 2018... nearly six years ago. The kids are basically grown… Two are long out of the house and the youngest is off to college in September! They are oh so much bigger now!
At the rate I am going -- trying to fit working on the Patrol in between work and family -- it's gonna take at least another 6 years before I'll ever get to drive it again... if even that soon! Then there are still the other two Patrols and my dream of three running Patrols!
The progress over the six years since the crash? I've:
• Stripped Aerogirl down completely
• Had the frame blasted and powder coated
• Got a replacement radiator support
• Had the body panels all blasted and primed
• Made a new front bumper (it’s even powder coated!)
• Had the rear axle rebuilt
• Had the F&R axle springs rebuilt
• Did a disk brake conversion (OMG that was a ton of work… although I have to admit that is the kind of challenge I like)
• Built a custom aluminum fuel tank (same size and placement as the original Patrol tank) -- with an in-tank electric fuel pump (again, the type of work I enjoy!)
• Recently I prepped the rebuilt, numbers correct engine and installed it into the frame
• I’ve even pulled the Marks out of the crate it flew over from Australia in and did the first test fit of the Marks to the engine... Still more work to do
Honestly, I think the two biggest roadblocks against progress are the actual lack of space and massive project scope!
It takes a ton of space to keep three Patrols on the driveway, not to mention that extra frame that serial number matches one of the rebuilt engines. Aerogirl's seats are tucked away occupying precious shelf space in the garage, new rear-side window rubber in a box on the shelf below that, Aerogirl's glass is tucked under my desk, there are boxes, and boxes, and boxes of patrol parts including some NOS stuff in the garage and on racking in the carport! It's amazing just how much space a disassembled Patrol takes up! More often than not, I have to move a ton of stuff just to do the smallest of tasks on the Patrol... when it comes to the Aerogirl project, it's often easier to just let that ounce of motivation be swallowed up by the pounds of work simply to get started!
My realistic expected future slow progress means that at my current rate, Aerogirl never gets done… well, not in my lifetime anyway! This means that I am at the proverbial crossroads – Keep Going… or Bail?
Perhaps there is something between those two extremes – let’s say I am at a three-way crossroads:
1. Do I keep nickel and diming it until I am too old to work on it any longer?
2. Do I make a package deal and sell it all off and then fade away into the sunset? (Someone would have to show up with a REALLY BIG truck to get it all!
3. Or make space & simplify to make progress easier?
I really don’t like Option 1… Option 2 just makes me sad. But option three may have legs!
I think if I were to free up substantial working space and simplify my project goals, I think the rate of progress on Aerogirl would go way up -- meaning, that middle option could work!
I had visions of getting three Patrols up and running. In an-armchair-quarterback-hind-sight-obviousness, I clearly bit off way more than I can chew. BUT, what if I part with the two extra Patrols and focus on one? (that would yield a huge chunk of work space and simplify the project!). I could even send the spare rebuilt engine off to adventures without me. I mean, I’ve never had plans for a dual-engine Patrol… Plus, while having visions of my Patrol Fleet, I have accumulated spares galore… When I needed one engine rebuilt, I got two rebuilt. When I needed one clutch and pressure plate set… I got two sets rebuilt. I needed one parking brake… Sending those out into the world will free up tons of space here and maybe help keep another few Patrols on the road!
I miss driving the Patrol and the adventures with Em and the kids...
Happy Tuesday all!
j
Happy Tuesday all!
j
Great write-up of a genuine Patrol owner and lover.
I have two Patrols on the road (and use them for Camping/4WDing and daily ride sometime). I've been working with them for over 10 years. I now have 2 others as spares or projects!
I got into them when I retired, having owned one in the 1970s. You still look fairly young so when you retire you will have some great projects.
Remember. Patrols keep you young and active.
But I usually do!!!
But I usually do!!!
Sheesh, I remember those kids!
Tough decision. As long as you are capable, you're never too old. With kids who have Patrols in their blood I think one is not enough. My .02.
- Has thanked: 6022 times
Excellent write-up John. I’ve enjoyed every word.
Peter and Leslie have some good thoughts. I’m sure you won’t regret their advice. And all of us will keep enjoying your progress and pictures.
Incredible how your kids have grown!
