1967 Family Patrol Project
zed
Has thanked: 203 times
Been thanked: 679 times
Post by zed »
How do you minimize flash rust.
Has thanked: 646 times
Been thanked: 1149 times
Post by faux40 »
Honestly, not sure! My plan is to prime the outside right after drying it, then rubbing some oil (wd40) on the inside.
Ideas?
Has thanked: 7721 times
I was always under the impression that metal needs to be primed as soon as it's stripped to prevent flash rust. Bare metal is going to rust.
zed
Post by zed »
Baking soda mixed with distilled water may neutralize the acid. I recommend not using tap water (impurities including chlorine.)
Post by faux40 »
So, I pulled the parts out of the vinegar bath and "rinsed" them with the pressure washer. Honestly, I only needed to "gently" wash them off... the rust really just rinsed away. It was pretty exciting!
Check out the fresh parts! I hand dried them immediately after their bath then put them in front of a fan to finish drying them off. The surface rust was already starting!
8728
So, a quick wipe down with acetone and slapped some conversion primer on the parts to stop that surface rust in its tracks!
8729
Next into the dip... the bell housing goes into the dip! Here are the before pics... That surface rust is deep!
8730
8731
Sadly, the "dip" is not quite deep enough to get it all submerged at once (and I already have to dispose of 13 gallons of vinegar... I don't wanna add more), so I plan to flip it every 12 hours or so. This is the part that was submerged for first 12 hours... Still has a way to go, but you can see some clean metal around the edges!
8732
J
Post by faux40 »
I pulled the bell housing out of the vinegar bath and gave it a pressure washdown
These two were taken at 2:57pm moments after the wash down was done. Looks great! Nearly all the rust and crust are a thing of the past!
8733
8734
As soon as I was done pressure washing, I gave the bell housing a wipedown with a towel, then set it in the hot California sun (97 degrees today) with a fan blowing on it to speed the dry off. I took this picture at 3:51pm -- just a mere 54 minutes later
8735
Wow! What were we saying about flash rusting?
Next I gave it a quick acetone wipe down, then covered it with a rust-conversion primer (the same black stuff I used on the pan and valve cover... I just forgot to take a picture of it), then two coats of the blue engine paint. I didn't worry about bolt holes, mating surfaces or the brass bushings -- I'll clean those surfaces and replace those bushings later... I just don't want any avenues for rust!
8736
8737
Gettin' closer and closer... well, still a long way from drivable, but it's nice to see progress!
j
Has thanked: 6022 times
Looks great John!
Like candy! Excellent job with the vinegar.
Has thanked: 209 times
Been thanked: 107 times
Post by timber »
Dang! You do good work. Thanks for the play-by-play.
Your easy outs are like mine: neither easy nor out.... :lol:
Tom
Modelo 1976 L60
Batalla 2200mm
Cilindrada 130 a 3956cc
Post by faux40 »
This has been sitting on my hydraulic lift table, hiding in a dark corner of the garage since December 22, 2014! It's rebuilt and raring to go! Plus, once this is on the engine stand, I get my lift table back! ;-)
8738
Here's the post when we brought this engine home from Mother's Machine Shop! https://www.60patrol.com/forum/viewtopi ... 250#p25250
Really, the only reason why this one is going into Aerogirl and not the rebuilt engine that was in it previously is that this engine is Aerogirl's original engine, so it serial number matches the VIN tag... but that does lead me to my side note, as Aerogirl goes back together, I think it's probably time to part with some of my extra patrols and parts (including the other rebuilt engine with just 1,500-ish miles on it that number-matches one of my parts Patrols!)
Enjoy your Friday and long weekend!
j
Incredible. Seems like I read that post 3-4 years ago.
Makes sense your choice!
