Main bearings
Has thanked: 1 time
Been thanked: 7 times
Re: Main bearings
Post by quentin.vds »
G'day,
Just want to confirm bearing numbers.
I've found a seller with MS1569P 10 thou main bearings but he says they are NDC.
It appears that MS1569 is a clevite bearing number and the NDC bearings CWallace has is a different number again.
Will the bearings still work?
The seller is Competition products aus if anyone knows whether or not theyre trustworthy (im still skeptical about ebay)
Has thanked: 6013 times
Been thanked: 1600 times
Re: Main bearings
quentin.vds wrote:G'day,
The MS1569P main bearing set is incorrect. They are for the P40 engine.
I am going to edit my previous posts here, since I have made a couple of members buy the wrong set.
The correct set part number for the P engine is MS-1001GP
Clevite just rebadges the NDC, the actual manufacturer.
