Reed Style Fuel Level Sender
Has thanked: 97 times
Been thanked: 568 times
Re: Reed Style Fuel Level Sender
Post by jwgreen »
WOW!!!!!
I step away for one day to move my mom and there's a whole page of info!!!!
There's a lot of electrical jargon and technical speak being thrown around on this thread :lol: :lol: so let me ask a simple question,,,
I can have the senders made in whatever ohm range is needed, I chose the 10-100 ohms because it hit both style numbers, So is there a better range that would suit both gauges better or is the 10-100 range the best to work with? I was hoping that there wouldn't be any need to add resistors and such with this new one. :doh: :doh:
Also, thank you to everyone who are contributing to this thread with technical information. I know very little about electricity and your input is invaluable and much appreciated.
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
In theory (weasel words), if you made the device to be 10 - 90 ohms then someone could just put a 10 ohm resistor in series to make a 20 - 100 range. It seems sensible, but I wish I had a wiring diagram for the older style. Any other opinions out there from electronics specialists?
Has thanked: 42 times
Been thanked: 247 times
Post by Johnny Roadkill »
Agreed, based on the data given - a 10/90 range would replace the older style sender exactly and require a simple 10 ohm series resistor to suit the newer style.
If you went 20/100 it would replace the newer style exactly but if replacing an older style sender a 910 ohm resistor in parallel would make full read right but the gauge would read ~10% fuel left when the tank is dry.
One other thing that should be considered is the power rating of resistors used - without measuring actual voltages in system, I'd recommend the 10 ohm series resistor should be rated at 5 watts minimum or it may burn out when the tank is near empty. Larger value resistors in parallel like 910 ohm can be 0.5 watt types.
Cheers,
D
Johnny Roadkill wrote:Agreed, based on the data given - a 10/90 range would replace the older style sender exactly and require a simple 10 ohm series resistor to suit the newer style.
Cheers,
D
I would say Mr. Ohm agrees; 5 watts. Place the resistor under the dash to prevent weather impact.
Justin-
You can count me in for one...
Has thanked: 514 times
Been thanked: 631 times
Post by rdarnell »
not sure if I need one but at that price (70ish?) I am game. put me down for one.
Richard
Has thanked: 48 times
Been thanked: 151 times
Post by Slackd »
As a new Patrol owner, in an effort to clean up under dash wiring, I tossed(!) my gauge regulator, not knowing its purpose. Just now figuring that out. My temp and fuel gauge function but read way hot.
Reading through this post, if I purchase and reinstall a 10 ohm 5 watt resistor I’m back in business? Like photo attached.
Thanks
Dave
Has thanked: 7728 times
No. A resistor works differently than a regulator.
Post by Slackd »
Thanks. I figured that would be too easy. My punishment for throwing out a key part without understanding it’s purpose.
So, any idea where I can buy ye olde gauge regulator?
Also, River, I’m the one looking for a Rochester B carb insulator. Any luck finding a NOS in your vast store of parts?
Thanks. As always.
Dave
Has thanked: 22 times
Been thanked: 113 times
Post by desertrat »
Slackd wrote:Thanks. I figured that would be too easy. My punishment for throwing out a key part without understanding it’s purpose.
Thanks. As always.
Dave
Not sure of any new old style (electro-mechanical) replacements available. I wrote a piece that's a sticky in electrical that explains the gauge systems. They run on 8 volts instead of the more popular 5 volts so there aren't really any swaps available.
If you do a search in the Datsun community, i.e. 1200, you will find a great many homebrew regulators ideas using various solid state components. There is at least one Datsun car parts supplier that offers a solid state unit for a pretty penny.
