water pump
- Been thanked: 4 times
water pump
I have 69 g60 that I need a water pump for Are they still available and information would be great.
- Has thanked: 7687 times
- Been thanked: 2476 times
Re: water pump
These folks can rebuild yours: http://www.kelloggautomotive.com
- Has thanked: 201 times
- Been thanked: 677 times
Re: water pump
Will this water pump fit the P engine? (I had read some earlier posts of some water pumps having zerk fitting. This pump does not appear to have such.)
Also, this pump has been sitting on a shelf for several years. Do you think the seals and gaskets would still allow the pump to function and not leak?
Finally, what does it cost to have Kellogg Automotive rebuild a pump?
Thanks,
Thanks,
- Has thanked: 6010 times
- Been thanked: 1600 times
Re: water pump
That pump will fit perfectly!zed wrote:Will this water pump fit the P engine? (I had read some earlier posts of some water pumps having zerk fitting. This pump does not appear to have such.)
Thanks,
This is a revised model, with a sealed bearing. From my own experience with this type of pump, it will outlast the "zerk-type" by far.
Being a sealed bearing, it will be ok, and since the seal is actually a carbon face touching the impeller, nothing to go wrong there. Either buy it, or I'll pm you with my address
Re: water pump
Esteban,Esteban wrote:That pump will fit perfectly!zed wrote:Will this water pump fit the P engine? (I had read some earlier posts of some water pumps having zerk fitting. This pump does not appear to have such.)
Thanks,
Keith![]()
Thanks for the confirmation!
I made the seller an offer...if he doesn't accept you are next in line.
Re: water pump
Thanks Keith.
I’m actually ok regarding the water pump. Have one that I rebuilt myself as a spare, and installed is one sourced from Colombia since 2012. Might be made over there.
Both pumps are like the one in your picture.
Esteban
Esteban
