I am not a big fan of the original late model FJ40 hubcap and I also hang out with too many LC friends so I wanted something a little cleaner and different. Enter the 1970's Pontiac welded to the cutdown mounting flange of the Land Cruiser hubcap.
my 1967 patina project build
- Has thanked: 514 times
- Been thanked: 631 times
I decided not to use the original split rims and purchased a set of Land Cruiser rims with just the right amount of patina. I had planned to use the original hubcaps and really like the smooth clean look.
- Has thanked: 7721 times
Now there's a sight you won't see often.
Nothing too exciting going on lately, been busy with other projects and other peoples projects but I did take some time to play with my clutch linkage and tried to find the best of 3 setups. There are some holes that are less than round and a couple of the linkage rods have significant wear. I was able to weld one up and regrind it though. Some parts were blue and some black so I just repainted them to what they last had on them.
- Has thanked: 6022 times
They look very nice!! Congratulations.
Years ago I did fix all the play in the linkage like you’ve done, but relied on a guy that was good at welding and shaping. I did myself was to add a grease zerk in the idler support with the two brackets.
I was thinking about doing that too. Mine moves freely but the other two from the parts rigs are seized. I used some heat and got one apart and cleaned it up some but is pretty pitted. Thinking I might enlarge the hole on the bottom that way the grease will flow to the ends and not just find the shortcut.
- Has thanked: 27 times
- Been thanked: 17 times
rdarnell wrote:It has been a busy spring so far and I have not been able to work in the garage as much as I had hoped. It might only get worse in the next few months but I was able to get a little something done over the weekend. Go the axle back together and started installing the disc brake conversion I made earlier this year. I have posted some details of the build in the modification area of the forum.
Are the v6 Toyota calipers a typical swap? I’ve done a few swaps using the land cruiser rotors and v6 calipers, fj80 master cylinder and dual diagram booster. I noticed the lack of room for a booster, has anyone used hydro boost? I was considering swapping in a vortec. If I go through with it, I will build different axles.
Not really sure what others are using. I had a pair of calipers on the shelf that I had left over from my old 4runner so I started there. I also had the old rotors from my 77 land cruiser and new ones for the 4runner but both were a little shallow. After researching some specs I found a pair that was deeper and allow the caliper to sit back and reduce the amount of spacer needed. I have not gotten to the master cylinder yet but I have seen some where they added a spacer to make some room.
Here's some discussion on that: viewtopic.php?f=21&t=2350&p=47717&hilit=calipers#p47717
Yes it is. My fathers cj3 jeep also has this setup. The formal name is tracta joint.
