Temp Sending unit/ Temperature Sensor
- Has thanked: 28 times
- Been thanked: 31 times
So I tested my temp sending unit and it appears to be faulty. When I checked the resistence at various temps ranging from room temp to boiling, I failed to get any ohlms.... Anyway, does anyone have any suggestions on where to obtain one. My Patrol is a 66. Thanks again! Mark
- Has thanked: 97 times
- Been thanked: 568 times
Re: Temp Sending unit/ Temperature Sensor
You can use one of these to replace it with a bit of modification. This sensor fits in perfectly but doesn't have a "nut" to lock it into place. I took my old sensor, cut the end off, drilled out the center and it slides perfectly over the new one.
https://www.ebay.com/itm/SANKEI-OEM-MAD ... 1080789526
PM me if you need more details on how to do that.
Cool. this looks like it will work. However, last night, I found a forklift parts supplier who claims to have the stock sensors in stock. I ordered one. We will see if it indeed is the right one...jwgreen wrote:You can use one of these to replace it with a bit of modification. This sensor fits in perfectly but doesn't have a "nut" to lock it into place. I took my old sensor, cut the end off, drilled out the center and it slides perfectly over the new one.
Awesome!! Let me know if it is the correct one. I'll get one as a backup.poinrobe wrote:Cool. this looks like it will work. However, last night, I found a forklift parts supplier who claims to have the stock sensors in stock. I ordered one. We will see if it indeed is the right one...jwgreen wrote:You can use one of these to replace it with a bit of modification. This sensor fits in perfectly but doesn't have a "nut" to lock it into place. I took my old sensor, cut the end off, drilled out the center and it slides perfectly over the new one.
- Has thanked: 7700 times
- Been thanked: 2478 times
That sleeve nut is intended to be removable. They just usually get stuck on with corrosion. So the one you got looks exactly like stock.jwgreen wrote:You can use one of these to replace it with a bit of modification. This sensor fits in perfectly but doesn't have a "nut" to lock it into place. I took my old sensor, cut the end off, drilled out the center and it slides perfectly over the new one.
WOW!!! I would have never gotten the sleeve off without drilling it out!! But good to know that I didn't throw away that piece!!RiverPatrol wrote:That sleeve nut is intended to be removable. They just usually get stuck on with corrosion. So the one you got looks exactly like stock.jwgreen wrote:You can use one of these to replace it with a bit of modification. This sensor fits in perfectly but doesn't have a "nut" to lock it into place. I took my old sensor, cut the end off, drilled out the center and it slides perfectly over the new one.
- Has thanked: 203 times
- Been thanked: 678 times
Why you been holding out on us Keith?!!!!!?zed wrote:A primer on thermal transmitters
http://datsun1200.com/modules/mediawiki ... ntable=yes
Tax season has stretched out....all consuming....must resist....
zed wrote:Tax season has stretched out....all consuming....must resist....
