Need a rear axle nut lock washer
Has thanked: 37 times
Been thanked: 210 times
Post by yitzac1990 »
Need a rear axle nut lock washer, mine is a bit chewed up. Please let me know if anyone has one, or if I can use anything from some other vehicle?? Thanks!
...at least that I know of :D
Has thanked: 6029 times
Been thanked: 1608 times
Re: Need a rear axle nut lock washer
Please take a look at this thread:
https://www.60patrol.com/forum/viewtopi ... 352#p39352
Member Flaggoni there has some interesting finds. Using one for the lock washer, this comes:
https://www.usarollerchain.com/W08-Lock ... washer.htm
or this one that I have in my notes:
https://www.amazon.com/Whittet-Higgins- ... B01D82WPK4
Let us know what you find.
well after actually doing some research, i think I found the right part? washer is W-08, is this correct?
https://www.ebay.com/itm/NEW-Lock-Washe ... SwtcRcGSJm
and while im at it, i might as well get new nuts...are N-08 and NL-08 (left hand thread) the correct nuts?
Esteban wrote:Please take a look at this thread:
i didnt even see your reply, we must have posted at almost the exact same time...thanks! do you have any info on rear axle seals? The Nissan part numbers are discontinued and I cant find sizes to cross reference...
yitzac1990 wrote:..
Also in my notes I have the following for the rear axle:
Bearing: ATM 959
Inner seal: ATM 2116213 35x55x11 mm
https://www.napaonline.com/en/p/ATM2116213
https://www.amazon.com/35X55X11-Grease- ... 07J5LXV5G/
Outer Seal: NOS-550225 48x65x7 mm
https://www.napaonline.com/en/p/NOS550225
https://www.amazon.com/48x65x7-Rubber-C ... B00SVIPCFQ
edited with the links added
thank you so much, and thank you for posting the dimensions as well. what is stopping me from finding a lower priced oil seal with the same dimensions that you have listed? I should be able to use whatever seal I find as long as the dimensions are the same, correct?
Any seal of those dimensions will work. You have to keep in mind is that the original has a double lip, so water can’t go inside in case if doing some extreme forthing.
Most other trucks are single lipped.
Excellent choices. Good find.
I think they sent me the wrong seals! for the outer grease seal, I was supposed to have 48 ID, and they sent 45 ID. Gahhh.....hopefully they can send the correct ones ASAP....
