Front Hub Lock Washers?
Original and compatible parts
Has thanked: 37 times
Been thanked: 210 times
Post by yitzac1990 »
im in the process of a mild rebuild of the front knuckles, and noticed what I think is the lock washers for the 2 large nuts that hold the hub on, are kind of chewed up and weren't even holding the nuts in place. On one side it wasn't even in the right location. Where can I get new lock washers for these hub nuts? I checked the compatible parts list, but the Nissan part number there has been discontinued.
Also, just to be sure, can someone give me the correct order of assembly for the 2 large nuts, the thick thrust washer, and the locking washer?
...at least that I know of :D
Has thanked: 81 times
Been thanked: 173 times
Re: Front Hub Lock Washers?
Post by nizmut »
Bearing, thrust washer, Nut, lock, nut. I want to say dana 44 from a ford bronco for the washer. I'll see if I can find the package in the shop.
Robin
Post by nizmut »
nizmut wrote:Bearing, thrust washer, Nut, lock, nut. I want to say dana 44 from a ford bronco for the washer. I'll see if I can find the package in the shop.
Found it in my rat house thread
http://60patrol.com/forum/viewtopic.php ... &start=120
page nine
spindle/nut
thread = 1 5/8”-16
Doorman 05304 or 615-126 (I believe both are the whole kit)
Pik-A-Nut 305304.1
NAPA 630-1654
Robin
thanks so much! so if i order a spindle nut it will come with the lock washer?
after researching those numbers, I found the NAPA part doesnt seem to exist, pik-a-nut leads back to dorman (which also doesnt exist), dorman 615-126 is JUST the spnidle nut, and dorman 05304 is the "kit" which contains 2 spindle nuts, 1 thrust washer, and 1 lock washer.
Thanks!!
doing even more research...i jumped on rock auto and searched that dorman kit part number. it fits a 1970 Jeep CJ5 (among a lot of other jeeps), and rock auto had a part number for just the lock washer for that vehicle, which is a Dorman 618-045. Here are its specs:
Spindle Washer
I.D. 1-5/8 In.
O.D. 2-3/16 In.
Thickness 3/32 In.
I found a similarly-sized spindle washer WITH the bendy tabs on it, Dorman 618-041. It fits Chevrolet 1991-81, Ford 1998-80, and GMC 1991-81, so its real easy to find the part. Here are its specs:
Spindle Washer
I.D. 1-5/8 In.
O.D. 2-1/2 In.
Thickness 7/64 In.
I am thinking of trying the tabbed option to see if it will fit...that way its a bit stronger (slightly thicker) and the tabs are already there for hammering onto the flats of the nuts. what does everyone think??
Has thanked: 6031 times
Been thanked: 1610 times
Great find! :clap: :clap:
My only concern is that it will be almost impossible to bend the Dorman 618-041. It looks that the way you secure them is different, so you might need the matching nuts.
I think I will order 2 of each washer and see which works out better. Pay day tomorrow haha
just a little update...i guess I was wrong, the washer that I thought was the lock washer, was the thrust washer....way too thick to bend over (thanks Esterban).
I am not sure what the part number is for the lock washer specifically, but I was able to make my current lock washers work and get the hubs back on the spindles.
