Where has Rob been these past few months...?
I've been busy, that's where. 8-)
I put up a sail shade over the concrete apron behind the garage, where I do all the cleaning/degreasing, sanding, and stripping on all my large parts.... Keeps the sun off my bald head from about 8am to 3pm every day... :geek:
And, I decided to put the last remaining piece of my red 65 donor patrol to good use- I chopped up the frame, removed the 2 center cross members and all the shock and engine brackets, and made it into a roll-around body cart, to make it easier to do all the blasting, stripping, sanding, and painting on my restoration projects
Hard to believe that what was once this:
is now this:
I left all the body mounts in place, so now I can lift the body off my restoration project(s), mount it onto this cart, and can then work on the chassis, and the body, side by side... :ugeek: and, with the cross members out of the way, I'll be able to get up underneath the the body with the pressure washer and paint gun more easily...
Hopefully I won't get any commentary from the "I can't believe you did that to an intact frame" peanut gallery - This Patrol was always a "zero numbers matching" rig, and I didn't even have an ID number plate that matched the number on the frame (4-L60-02565); and the title I had for this Patrol said it was a 1962, which it wasn't - it was a 65 hard top. So, it's officially scrapped.
The body, the axles, the brakes, drivelines, and misc hardware from this Patrol will continue to live on as proper 1965 Patrol parts, as they have gone into the restoration of L60-3-00617, and will help bring it back to life... 8-)
Has thanked: 7323 times
Been thanked: 2399 times
Re: Where has Rob been these past few months...?
Well it's nice to know that you have been able to put some Patrol time in. I just figured you had fallen off the face of the earth. ;)
Has thanked: 5859 times
Been thanked: 1549 times
This is what I will call a project within a project. ;)
It looks that you are very serious on the work that will be needed ahead. :clap: :clap: :clap:
Esteban wrote:This is what I will call a project within a project. ;)
Yes, that is exactly what it has been.
Other than that, the summer has been wearing me down - Just doing lots of large parts cleaning with the pressure washer (any task dealing with water is ok when it's 105+ outside 8-) )
That parts-donor Patrol under the tarp in the background of that picture is next on my attention-list. I have to get that one onto 4 good wheels (it's missing the rear axle and hub on the passenger side), and get it to the point that I can roll it around, so I can finish breaking it down into "keeper-parts", versus "ship them off to Mississippi" parts... 8-)
and don't ask about that upside-down Patrol body on the right side of the picture- More details soon to come about that, too ;)
Like I said- Lots going on around here.
