Modifying Wheels For Patrols
Has thanked: 56 times
Been thanked: 39 times
Post by Timoun »
One of the best methods I've found to accurately enlarge the center of GM wheels to fit the front hubs of Patrols is to use two hole saws. The small saw should fit snugly into the wheel's existing center, and the larger is the size of the Patrol's hub. The small saw serves as a guide for the larger, which makes a very accurate cut. I've had these wheels spin-balanced at tire shops that use a machine that mounts them to a center mandrill and they balance fine.
Has thanked: 6017 times
Re: Modifying Wheels For Patrols
Wow! That's creative!
Thanks
Post by Timoun »
Esteban wrote:Wow! That's creative!
Thanks
Thanks, Esteban. Short of having a lathe or taking wheels to a machine shop, this is the best way I've found to do it. Use plenty of oil when doing the cutting! :D
Has thanked: 351 times
Been thanked: 301 times
Post by mdawg4x4 »
That is creative. Amazing what you can come up with when the need arises.
Post by Timoun »
mdawg4x4 wrote:That is creative. Amazing what you can come up with when the need arises.
Thanks. Hope it helps anyone else who wants to do this. :D
