Salvageable parts
Original and compatible parts
Has thanked: 1 time
Been thanked: 51 times
Salvageable parts
I'm wondering what parts I can pull off a 69 parts truck that will be compatable with a 65 that I have?
Has thanked: 7700 times
Been thanked: 2478 times
Re: Salvageable parts
Most parts in the engine compartment, other than the alternator, wiring harness, fuse block and a few other things. Otherwise, almost everything else is slightly different. The seats are different, dash, gas tank, ignition switch, wiper motors, turn signal switch, etc, etc. The diffs are the same, and the transmission and transfer case would interchange even though there are some internal differences.
Has thanked: 1 time
Ok cool. I was hoping that the engine transmission t case an front and rear axles would be compatible. The rest ill take out a trade or sell.
Has thanked: 6013 times
Been thanked: 1600 times
mattmctree@gmail.com wrote:Ok cool. I was hoping that the engine transmission t case an front and rear axles would be compatible. The rest ill take out a trade or sell.
Let me expand a bit RiverPatrol comments:
RiverPatrol wrote:Most parts in the engine compartment, other than the alternator, wiring harness, fuse block and a few other things. Otherwise, almost everything else is slightly different. The seats are different, dash, gas tank, ignition switch, wiper motors, turn signal switch, etc, etc. The diffs are the same, and the transmission and transfer case would interchange even though there are some internal differences.
The front axle is slightly different, but totally interchangeable. Some components are exactly the same.
The rear axle is basically the same, with the only minor difference being the thread direction on one of the locking nuts for the wheel bearing. Can't recall which one. If you change a complete left axle for instance, it's a direct fit on the old axle.
The engine is the same. The transmission is the same with minute changes in a couple of bearings but same basic components. Transfer case is basically the same. Totally interchangeable.
Suspension components and steering linkage are the same.
Has thanked: 1 time
wonderful. thank you both for the info.
