Tub removal
Has thanked: 84 times
Been thanked: 327 times
Re: Tub removal
Post by miller »
Yes you could but you would need to be careful. The firewall is heavy and could bent the floor if not careful. I think 6 would be ideal.
Has thanked: 209 times
Been thanked: 107 times
Re: Tub removal
Post by timber »
Rolly wrote:Thanks all :clap:
Jeff, I see from your pic that your panel at the front of the tub is bigger than mine (I've got panel envy :shock: ) is that a SWB thing or maybe mine has been cut down as it's flush with the back box section. Here's some pics
I was actually wondering if anyone has cut and shut this panel to give more room to push the seats back. While I love this Patrol I remember my '71 seemed much more roomier (had the original seats), this one has my legs bumping into the steering wheel (I'm 6ft 2") and is generally uncomfortable with the gearstick sitting against my thigh.
I'm looking at making up some mounts to lift & fit the seats out of my Series 1 Discovery to allow for a bit more leg room but putting that panel back 8" would make a world of difference.
Has it been done that anyone knows of?
Rolly, did you end up cutting into the tub and tub divider to get more seat and leg room? Hope you're still around from 9 years ago....
Tom
Tom
Modelo 1976 L60
Batalla 2200mm
Cilindrada 130 a 3956cc
Has thanked: 12 times
Been thanked: 160 times
Re: Tub removal
Post by Dixonsix »
Hey Tom,
The previous owner of my Patrol cut the tub down even with the battery and tool box. From the look of the weld in the corners I am not sure if the tub can be separated without cutting the patch. I did not recognize this as atypical until viewing pictures on this page. I do not believe it was done to accommodate larger seats as the originals were in the rig when I got it. (currently at the upholsterer).
Now I just need to relocate the manual crank since half the wall is missing.
Has thanked: 7725 times
Re: Tub removal
A unibody. :roll:
