Moore_rb's 66 Ebay Patrol (re)build thread
Has thanked: 7740 times
I think it's officially reborn. :clap: :dance:
Has thanked: 646 times
Been thanked: 1149 times
Post by faux40 »
moore_rb wrote:
The I unhooked everything and removed the sender- it was totally siezed up - the armature did not swing at all:
To get the armatures unstuck and freely swinging, I dunked both the senders in my super secret "unseizing" concoction (diesel fuel mixed with Marvel Oil 50-50)
Did you soak both the outside and the inside? (e.g. did the resistive coil get wet with your super secret magic unseizing concoction?)
Affirmative... I soaked the whole thing, totally submerged, for about 5 hours -
Has thanked: 97 times
Been thanked: 568 times
Post by jwgreen »
I used CLR to clean and restore mine and it worked great. Just let it soak for a while then used a soft wire brush to help remove some of the crud. Then repeat the process till it's to your liking.
If you choose CLR, just don't soak it for very long - CLR is acidic (PH is around 2.0-3.0), and will attack the copper in the windings, as well as the brass on the float ... :ugeek:
CLR's own FAQ page recommends against using it on copper, brass and aluminum...
http://www.thecarycompany.com/container ... lrfaq.html
Post by jwgreen »
moore_rb wrote:If you choose CLR, just don't soak it for very long - CLR is acidic (PH is around 2.0-3.0), and will attack the copper in the windings, as well as the brass on the float ... :ugeek:
Ain't skeered 8-)
Yesterday I got the PTO driveshaft all hooked up and confirmed that the the winch works. :dance: The shaft sections were missing a couple woodruff keys , so someone had just reversed the shaft orientation and threaded a bolt through the tension bolt hole into the woodruff slots (have a I ever mentioned that this Patrol had a lot of hacked-up stuff on it?) - Now the winch driveshaft is nice and tight with the correct keys in place, and is back to full-strength.
I also installed a battery tray and tie-down bolt kit from the local auto parts store; so now my battery is nice and snug, which allowed me to install the floor pans beneath the seat. Now I don't have to worry about hitting a bump and having the battery ground out on me 8-)
Has thanked: 6027 times
Been thanked: 1607 times
Good progress, Robert.
How about some pictures, or...?
Esteban wrote: How about some pictures, or...?
Sure- I have a couple recent pics (pardon the dirt- it rained the night before, just enough to get everything dirty ) :evil:
My "government issue" center console fits between the seats perfectly, and also seems to fit the character of this vehicle:
And, it's officially a "Nissan" again....:
In fact, it's a "Nissan Patrol" :
Yesterday evening was a fun one - I took the Patrol to run out and grab some drive-thru action (no, not Taco Bell ;) . I got my food, pulled out into traffic, and felt a somewhat familiar "chug.... CHUG" feeling; so I U-turned it and tried to make the banzai run for the gas station on the corner, but to no avail - dead on the side of the road.... CHUG...... {wheeze}
{Rinnnnng}..... {Rinnnnnng}
"Hello?"
"Hello Dearest, Love of my life, Greatest Wife on Earth..."
{awkward pause}.... "What happened?"
" :shifty: :shifty: :shifty: :shifty: Well, I have dinner here with me, but do you think you could come and get it...? Oh, and bring one of the gas cans from the garage along with you please... :oops: "
"You're out of gas...?"
"Well, I hope that's all it is :handgestures-fingerscrossed: , but yeah... I'm sitting here on the side of the road... :confusion-helpsos:"
{Awkward pause #2}...... followed by .... {hysterical laughter} :laughing-rolling: :laughing-rolling: :laughing-rolling:
15 minutes later, She is driving home with the kid's dinner, while I am pulling the last 500 feet or so into the gas station to finish fueling up...
Note to Self- When gas gauge reads 1/4 tank remaining - go to gas station.
Post by faux40 »
Ha! I suspect that will be me someday soon!
We might be able to "calibrate" the gauge...
