Converting to dual reservoir brake master cylinder
- Has thanked: 257 times
- Been thanked: 270 times
Re: Converting to dual reservoir brake master cylinder
I like the schematic depiction (page 8?) of the "slave" master cylinder being in series. It made what Esteban tried to tell me about why the pedal pressure and travel wouldn't change finally soak in. I submit.
Mild Bill
Mild Bill
- Has thanked: 310 times
- Been thanked: 176 times
Somebody ate my brains and I cannot compute this.....good thing the stock system is working good enough....
Nice work guys
....beyond good enough!!!
Nice work guys
- Has thanked: 646 times
- Been thanked: 1149 times
moore_rb wrote:Just a quick update on this topic- I decided which Master Cylinder I am going to use on my green Patrol:
This is a dual reservoir, dual circuit, one inch bore MC originally for a 1967 Chevrolet C10 pickup 4x2, with 4 wheel drums and built in 50/50 bias - $26 at the neighborhood O'Reiley Auto Parts Store:
Based on my research, this one should offer nearly identical braking power and pedal feel to the stock Patrol MC, but with the benefit of isolated front/rear circuits...
Nothing left to do but fab up an adaptor for the bolt pattern, hook it up, and see if I'm right...
Hey Rob -- Any progress on the dual master cylinder replacement?
- Has thanked: 800 times
- Been thanked: 1269 times
No, I've been slackin...
Hmmmm maybe this Saturday- the schedule looks clear so far, and I'm sure the kids will be sleeping in late due to their "day after Halloween" sugar-induced insulin comas...
- Has thanked: 51 times
- Been thanked: 49 times
I was thinking about doing this as well since my brake system needs an overhauling but now my head is spinning from reading all of this.
I'm waiting for Rob to complete the conversion, become the crash dummy and then, if successful, provide the howto doc on dual MCs!XploreNV wrote:I was thinking about doing this as well since my brake system needs an overhauling but now my head is spinning from reading all of this.
I still plan to use this GM MC on the "next iteration" of the 66 El Paso Patrol, but it's going to be awhile...
For anyone looking for a 100% bolt in dual reservoir MC for their patrol - just order one of these:
http://www.ebay.com/itm/Brake-Master-Cy ... 75&vxp=mtr
This is the exact MC I am going to build my 65 hard top with, and when I get to that point in my project, I will do a "how to" on converting your Patrol from single circuit to dual circuit brakes...
- Has thanked: 42 times
- Been thanked: 73 times
Hi all
So I'm looking at the 1" Wilwood MC that was sold by silvermine/californiadatsun/datsunlandsocal & which is pre-modified for early Z cars and a couple things came up that I wanted to mention to you all ...
The center to center dim for the MC mounting studs on the Patrol firewall is approx 65mm
The 1" Wilwood MC even after the holes have been opened up for an early Z car is more like 55-57mm center to center.
By the time you open it up to get to 65 there won't be much of stock casting left ... the washers between your mounting stud nuts & the wilwood MC look like they will be half on / half off ... You all ok with this ?
Also, I noticed that the rod that pins into the brake pedal and operates the MC piston is some 15mm too long and would need to be shortened...
Again, you ok with this ?
Has anyone actually used the Wilwood 1" MC on their Patrol ?
- Has thanked: 6023 times
Looking at some at the following thread,
http://www.60patrol.com/forum/viewtopic ... ood#p26526
Justin (jwgreen) has modified the mounting holes, although I couldn't see any pictures, just the master cylinder installed. Beautiful work. I hope Justin can chime in with your concerns.
Besides some aesthetics, if at all, you'll be ok. After you do it, please post some pictures.
- Has thanked: 351 times
- Been thanked: 301 times
My 67 already had a modified Wilwood style (don't remember the name on the side). It had both holes over sized with the lower one slotted and over sized washers holding it in place.
I replaced it with a new Wilwood and installed it back in the same manner. Had I put a little more thought into it, I probably would have ordered a master cylinder from 4WD Australia off e-Bay.
