Starter, radiator an other stuff.
doc
Has thanked: 4 times
Been thanked: 10 times
Post by doc »
Looking for a starter and radiator for my patrol as mine are dead.
Also looking for an engine,trans and transfer case to have as rebuilds.
Thanks
Doc
doc
Re: Starter, radiator an other stuff.
Post by doc »
Still looking......
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
I might have a starter for you. I will check it and make sure its ok. I will let you know.
Has thanked: 7744 times
What's up with the radiator? I have yet to see one of those fail, unless something is shot through it.
Has thanked: 42 times
Been thanked: 247 times
Post by Johnny Roadkill »
RiverPatrol wrote:What's up with the radiator? I have yet to see one of those fail, unless something is shot through it.
mine failed :(
my local radiator bloke reckons he's seen more than one 60 Patrol radiator split the brazing between tanks and core - usually because the original 7psi cap has been replaced by a 13psi, which is more commonly available here. Apparently the shape and size of the 60 radiator means it doesn't like having nearly double the design pressure inside it...
cheers,
D
Yes, that would make sense. That's a lot of copper to be tossing out, hopefully you can recycle the old one to help pay for another one.
RiverPatrol wrote:Yes, that would make sense. That's a lot of copper to be tossing out, hopefully you can recycle the old one to help pay for another one.
Actually the core itself was ok, after a good flush. Just needed to have the tanks removed, repaired and replaced - and have the correct cap fitted. :shifty:
New cores are pretty steep ( AU$700-$900 fitted ) thanks to lack of competition in Australia, but at least they're available.
cheers,
D
doc
Post by doc »
2869ral wrote:I might have a starter for you. I will check it and make sure its ok. I will let know.
Thanks!
doc
Post by doc »
the radiator is leaking from the rear, not sure what happened to it. My concern is the small issue becoming something catastrophic on a longer trip. If I cant find a stock one I may have a custom one made, I am just trying to deal with all the issues especially while i cant drive it anyhow.
Thanks
Doc
