Well got the call this morning that Ross was coming over. Quickly got into the garage and started cleaning up getting ready to work.
Got started and started welding up the crossmember, long range tank mounts (I even had a go, on the TIG and it’s easy compared to ARC, I want one !!!) Then dug out the hole in the crossmember for the front tailshaft.
Ross just used the scrap 5mm plate and made a jigsaw and done. Also welded the spring hanger mount and a few other bits.
Photos. !! Here they come. Hopefully I’ll clean the welds up this weekend and may even start painting.
Steve
Ross getting into it
Ross did the right side, I did the left. Hehehehe I can TIG weld
That crack is no longer
New hole in the crossmember
First 5mm plate in the hole
More plates in there
Raw finished product
Thanks Ross !!!
Got to love all the toys in the drive
