Speedometer
Has thanked: 652 times
Been thanked: 632 times
Re: Speedometer
Post by Coyote Patrol »
Andrew wrote:I got the cable at Knechts. It is ATP brand part number Y-872. Here is a link to one on Amazon. http://www.amazon.com/ATP-Y-872-Speedom ... B000C8TBL4
Bummer just got this cable, its not a speedo cable, it's a throttle cable for ???? :doh:
Has thanked: 7721 times
Re: Speedometer
Wow, it sure looks like a speedo cable in the listing. Did they package it wrong?
Has thanked: 6022 times
Re: Speedometer
2869ral, you should buy the lottery! What are the chances of misplacing a throttle cable for the speedometer one?
With that number, I was able to find it at other part stores, like Rockauto. Supposedly fits a number of Datsun/Nissan and one Toyota LC.
Re: Speedometer
Must have been packed wrong. Yep just confirmed it, it's boxed wrong. :cry: :roll: :x :violin:
Has thanked: 12 times
Been thanked: 13 times
Re: Speedometer
Post by Andrew »
2869ral wrote:You are welcome, i love doing this stuff! :D Did the DS115 dimmer switch fit? Bolt holes were good?
The dimmer switch does fit and the holes are good.
I spent a lot of time running a new wire today and I couldn't get low beams. I am still not getting voltage from the switch to the low beam wire.
My fuel gauge also stopped working today. I must have done something to it. This truck is definitely putting me through the paces.
Re: Speedometer
Sounds like the new dimmer switch is not connected properly.
Re: Speedometer
Post by Andrew »
Success! Thanks to Ron I have low beams and high beams! :dance: I included a picture for proof. Ron is the man! Thanks for your help buddy!
Has thanked: 5 times
Been thanked: 8 times
Re: Speedometer
Post by OldLRRP »
I know this is an old thread, but what was the final outcome? I need a speedo cable for my '69. Any help?
Leading the Way since 1968!
Re: Speedometer
Been thanked: 1 time
Re: Speedometer
Post by hoyt »
OldLRRP wrote:I know this is an old thread, but what was the final outcome? I need a speedo cable for my '69. Any help?
did you ever get a good number for speedo cable....?
I have a 67......should be the same.....
