G60michael wrote:....My biggest concern at the moment is Now Oil Starvation if i was to run the drawn cup rollers. The only other option maybe to run 2 Skinner drawn cup rollers either side of the oil feed hole in the gear teeth ?
One more thing that comes to mind is running the 2 bearings side buy side, if one happenes to seize up and the other doesnt, that would then damage the imput shaft
It looks that you are on the right track, and between what you've find there and some ideas thrown here, a solution for this cases can be implemented.
Your idea of leaving the oil hole uncovered by the drawn cup rollers can work. The question will be how to prevent them from sliding together and covering the hole?
Initially I thought that the oil level will be partially covering the shafts, but it looks that it's lower. The following is a picture of my transmission showing a filler plug that I installed years ago. In red you have the oil level and in yellow the position of the input and output shafts (the perspective might be deceiving, but definitely the center line of the shafts is higher than the oil level). The oil gets in the needle bearing due to the splashing inside the case, and then, since the shafts are rotating, actually the oil will flow out of the recess in the output shaft, towards the 3rd gear synchro ring due to the centrifugal force. Just theory at this point
. If that's the case, the splashing of the oil inside will also get to the other parts, making the hole redundant.
I will not be concerned with one of the drawn cup rollers failing. It might happen but after a long time. If this vehicle is going to be your daily driver, maybe of some concern, easily taken care with a dismantle of the transmission after 2 years. Otherwise, it will be good to go for the rest of its life.
Michael, you'll have to inspect all this and tell us what you think. Also, please take some pictures of the solution that you finally implement.
