Won't stay running
- Has thanked: 7743 times
- Been thanked: 2482 times
Won't stay running
I was going to take the Aussie pickup in to town so I went to warm it up. It started up ok with the choke, so I walked away to go get something. I got as far as the tailgate and the engine died. I thought, hmmm, and went to restart it. Again, it started up fine, but a couple of seconds later it dies again. This continued to happen, so I took another vehicle.
I spent some time today trying to diagnose the problem. It's not electrical, it's still got power to the coil when it dies. I watched the carb, and the spray of fuel in the throat stops right before it dies. The fuel filter is fine. I replaced the fuel pump and it still dies.
This is a Stromberg carb. Is there possibly a problem with the carb? It ran great the last time I drove it. There is a little bit of gas seepage coming from under the float chamber.
Help?
Help?
- Has thanked: 646 times
- Been thanked: 1149 times
Re: Won't stay running
faux40 wrote:I think it wants to live in Northern California... We're happy to host it
- Has thanked: 652 times
- Been thanked: 632 times
I think you have a sticky float, can you tap on the float bowl without damaging the carb? I would try that first. Then maybe disconnect the fuel line from the carb and spray carb cleaner into the connector to carb.
also double check and make sure none of the rubber fuel line is cracked, or coming apart internally.
If that doesn't work i think it wants to live in NORTHERN ARIZONA!!!!
Thanks, I'll check that. I can tap on the float bowl without damaging anything.
Northern AZ, huh. It might make it as far as Williams some day if I take it to the Datsun meet there.
I might have to do that as well. Its only an hour and a half from Winslow.RiverPatrol wrote:Thanks, I'll check that. I can tap on the float bowl without damaging anything.
Thats weird, i just remembered. I used to work for my grandmother in Valley (junction of 180 and 64) at her trading post during the summer. We used to drive her Patrol (the one i own now) to Williams to go grocery shopping.
agree with Ron- sound like either a float issue, or the needle is stuck in the seat in the carb.
Good luck - I hope you get it figured out
Very cool.2869ral wrote:Thats weird, i just remembered. I used to work for my grandmother in Valley (junction of 180 and 64) at her trading post during the summer. We used to drive her Patrol (the one i own now) to Williams to go grocery shopping.
