by GARYSCC » Sun Sep 15, 2013 6:12 pm
I am trying to figure out how to connect my e brake. It seems like my rod is not correct for my 1967?
GARYSCC
- Images: 23
- Has thanked: 1 time
- Been thanked: 10 times
by Esteban » Sun Sep 15, 2013 8:35 pm
Gary, it looks correct to me. The only picture I have at hand is the following:
I can measure tomorrow the length so you can compare with yours, but I'm sure it's correct.
Esteban
- Has thanked: 5588 times
- Been thanked: 1441 times
by RiverPatrol » Sun Sep 15, 2013 8:40 pm
Esteban beat me to it.
The rod is correct for your '67. The rods didn't change between years, pretty much nothing did on the hand brake. I can see that you will still be missing the adjustment bolt that is the smaller one to the right of the larger one with the spring on it.
- Images: 959
- Has thanked: 6804 times
- Been thanked: 2297 times
by Esteban » Mon Sep 16, 2013 6:54 am
GARYSCC wrote:haha. thanks again Esteban & Leslie - the picture and info was very helpful. Leslie had given me the the diagram previously, but I just didn't understand how it worked until I saw the color photo. Is the little bolt and spacer an important part of it to work? If so, should I try to find one on ebay or from one of you guys? Or, do you suggest I make one up myself?
You can make one yourself. After reading your post and looking at my picture, mine clearly looks fabricated. Have forgotten about it.
Esteban
by RiverPatrol » Mon Sep 16, 2013 8:44 am
Esteban wrote:GARYSCC wrote:haha. thanks again Esteban & Leslie - the picture and info was very helpful. Leslie had given me the the diagram previously, but I just didn't understand how it worked until I saw the color photo. Is the little bolt and spacer an important part of it to work? If so, should I try to find one on ebay or from one of you guys? Or, do you suggest I make one up myself?
I agree with Esteban. Just find a bolt long enough and use 2 nuts on the end to lock the adjustment. This is one of the 3 adjustments for the handbrake shoe.
- Images: 959
by miller » Tue Sep 17, 2013 4:33 pm
Esteban wrote:I can measure tomorrow the length so you can compare with yours
bosque wrote:Sounds like you have a handle but......haha ebrake.....handle......
ahh what a great start to my day
miller
- Images: 95
- Has thanked: 84 times
- Been thanked: 327 times
by GARYSCC » Sat Sep 21, 2013 9:19 pm
Hi, I noticed my shoe was upside down with the correct picture so I rotated it and re installed it. Its all done except the rod is is too long as shown. Were there shorter wheelbase patrols made? It looks like I will need to shorten my rod by several inches. Any thoughts?
GARYSCC
- Images: 23
Users browsing this forum: No registered users and 4 guests
