Carburetors: VC42 vs VHA
Has thanked: 3 times
Been thanked: 8 times
Re: Carburetors: VC42 vs VHA
Post by PanterA »
G'Day All,
Does anyone know where I can buy a rebuild kit for my VHA carby?
I'm currently working on rebuilding a January 1977 G60 Patrol. Engine idles really nice, however when pressing the throttle quickly, it almost stalls. If i gradually increase throttle, it revs up fine.
All indications seem to point to the accelerator pump in the VHA carby which is on it. I have put new points, leads and plugs in.
Thanks,
Matt.
1977 G60HWU PATROL, 4.0L, 3sp Manual.
2000 GUII PATROL ST, 4.5L, 4sp Auto, 5" Lift, 35x12.5 Bighorn, 80% reduction gears, Locker, ARB bar front and back, Winch.
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
If this carb has a leather cup on the accelerator pump and it was dry it will shrink. With any luck the leather cup could swell back up and start working. Keep your fingers crossed. I just can't remember if this carb came with the leather pump? :D
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
2869ral wrote:If this carb has a leather cup on the accelerator pump and it was dry it will shrink. With any luck the leather cup could swell back up and start working. Keep your fingers crossed. I just can't remember if this carb came with the leather pump? :D
Try East coast Auto Spares :) there in Melbourne, that's where i got a VHA kit from probably 3 or so years ago now
Been thanked: 28 times
Post by Pancho »
PanterA wrote: Engine idles really nice, however when pressing the throttle quickly, it almost stalls. If i gradually increase throttle, it revs up fine.
I had the same problem some time ago. First thing you have to do is inspect the plastic lever (A) if it shows too much wear in the surface where it gets contact with the diaphragm rod (D), or in the two holes, you have to replace it with a new one. Unfortunately it is not included in the NAPCO carb kits; maybe it is in other brand. This should fix your problem, but if not, like in my case, the problem is related with diaphragm rod, it wears with the time and its length gets short enough so the pump can’t move as much fuel as it is necessary when you are depressing the gas pedal. One alternative is to replace to rod for a new one, again it is not included in the kit; so what I did is to make by myself a shortest link (B) in order to allow more stroke in the rod and consequently more volume in the pump. Now my Patrol works much better.
Hi all, Its had me thinking why is my VHA different to every other one I have seen. Its still got me think, but besides where the power valve goes through the top of the bowl, on my VHA there is another type thingy next to it, Attached are some photos of what it looks like, does anyone know why its got this on it ?
Cheers G60mike
none of the spare VHA's i got have this setup :think:
Post by Pancho »
G60michael wrote:Hi all, Its had me thinking why is my VHA different to every other one I have seen. Its still got me think, but besides where the power valve goes through the top of the bowl, on my VHA there is another type thingy next to it, Attached are some photos of what it looks like, does anyone know why its got this on it ?
Cheers G60mike
It is a "High Speed Enricher" mechanism as you can see here:
thanks Pancho, you are very very helpful, i need you to WEB diagnose my old 78 its playing up
Has thanked: 10 times
Been thanked: 17 times
Post by Keith »
G60michael wrote:
RiverPatrol wrote:Good to know. I already have a kit or two for the VC42 but could use a couple for the VHA. Thanks!
Kit numbers are
HT409 - Hitachi VC42 61- 1/69
HT410 - Hitachi VHA 2/69- 80
Correct me if I am wrong, but that's what fuel miser book said
I'm confused. My 69 has a VC42a & its production date is 6-69.
Keith Y. (npca-Danette&Keith)
Keith wrote:
Kit numbers are
Keith, by the sounds of things your carby has been changed and someone's bolted the VC42 to the manifold, a aussie patroller over here, recently purchased a 76 model with a VC42 on it, definitely been swapped.
Has thanked: 7728 times
Keith wrote:
G60michael wrote:
Kit numbers are
None of the US Patrols came with the VHA carb.
