Fastener grade
Postby zed » Thu May 12, 2022 6:43 pm
All,
I need to replace nut and bolt (Items 16 and 17) http://www.carpartsmanual.com/nissan/pa ... ht-loading.
Are these grade 5 or grade 8 fasteners?
Thanks,
Keith
zed Offline
Images: 153
Has thanked: 161 times
Been thanked: 583 times
Postby RiverPatrol » Thu May 12, 2022 7:57 pm
#16 is a greasable shackle, #17 is a castle nut. I don't know that they are graded.
Images: 959
Has thanked: 6780 times
Been thanked: 2291 times
Postby zed » Thu May 12, 2022 8:29 pm
Castle nut would indicate cotter pin. No pin shown in diagram? Why LB, oh Why?
zed Offline
Images: 153
Postby RiverPatrol » Thu May 12, 2022 10:19 pm
:doh: You're right, I was thinking of the other end. Not a greasable shackle, although I have seen greasable bolts for that location before. The nut is a lock nut. Probably should be grade 8, for the bolt at least.
Images: 959
Postby Esteban » Fri May 13, 2022 8:03 am
RiverPatrol wrote::doh: You're right, I was thinking of the other end. Not a greasable shackle, although I have seen greasable bolts for that location before. The nut is a lock nut. Probably should be grade 8, for the bolt at least.
X2
That bolt has to be of a very high grade. Many members have had to cut the bolt because it has deformed under load and doesn't want to come out. The bushing that goes inside shouldn't rotate. The bolt is tightened to 65 to 87 ft-lb.
Has thanked: 5571 times
Been thanked: 1436 times
Postby faux40 » Fri May 13, 2022 3:34 pm
X2
I, being one of the "cutters" agree that the bolt is high grade... it did not want to be easily cut!
faux40 Offline
Images: 1310
Has thanked: 636 times
Been thanked: 1122 times
Return to Suspension & Steering
