Need Help on the Clutch!
Original and compatible parts
Postby ElkwoodNC » Wed Feb 15, 2023 6:20 pm
Hello everyone,
I'm new to the Patrol. I live in the states. I cant not find what clutch kit I need to order. Ive checked the forums but Im learning the system as well. Please Help.
ElkwoodNC
Brian
ElkwoodNC Offline
Lurker
Lurker
Has thanked: 0 time
Been thanked: 0 time
Postby r1lark » Wed Feb 15, 2023 8:37 pm
Hi Brian, welcome to the 60Patrol forum!! Great to see yet another North Carolina member.
Unfortunately, I can't help you out with a source for a clutch, but I'm sure some others will chime in here that can provide that info.
r1lark Offline
Images: 9
Been thanked: 569 times
Postby faux40 » Thu Feb 16, 2023 12:42 am
Many of us resorted to having ours rebuilt. I used Capital Clutch in Sacramento. Here's some info about my clutch (including the invoice)
viewtopic.php?p=20752#p20752
Good luck!
faux40 Offline
Images: 1310
Has thanked: 636 times
Been thanked: 1122 times
Postby Esteban » Thu Feb 16, 2023 3:55 pm
Member Desertrat mentioned this :
viewtopic.php?f=24&t=6092
you can search for a 11" clutch disc for Ford from 1942 to 1965 with 1-3/8" x 10 spline hub from some supplier here in the states.
For example: https://www.vanpeltsalesstore.com/81T-7 ... p_778.html
I ordered a similar disk from Rockauto.
At Rockauto use: FORD > 1958 > F-100 > 4.4L 272cid V8 > Transmission-Manual
M-PACT 280607 11" X 1-3/8" X 10T
I will try to do a dry test this weekend and do a comparison once and for all. The Ford clutch disk is dirt cheap at $50.
Has thanked: 5589 times
Been thanked: 1441 times
Postby ElkwoodNC » Thu Feb 16, 2023 8:03 pm
Thank you everyone. Im still learning about the Patrol. Please let me know about the ford clutch.
Brian
ElkwoodNC Offline
Lurker
Lurker
Has thanked: 0 time
Postby Esteban » Sun Feb 19, 2023 3:39 pm
Yesterday I was able to test the Ford disk clutch in the pressure plate/flywheel assembly.
Some measurements
Patrol FORD
Diameter10 7/8" (275mm) 11" (279.4)
Thickness0.374" (9.5mm) 0.374" (9.5mm)
As you see from the above measurements, the Ford disk is 0.173" (4.4mm) bigger, or 0.087" (2.2mm) bigger showing on each side of the pressure plate
It is very difficult to measure the clearance between the disk and the cover when assembled. Unfortunately I forgot to take the following picture with the Ford disk. There is big chance that it will rub on the pressure plate cover. Also, almost impossible to properly center it with the flywheel outside. One way to check could be to dismantle the pressure plate completely, and start checking without the pressure applied or just looking how the disk fits inside the cover. In the past, I have rebuild the pressure plate by taking it apart completely, but it requires a press to apply pressure to the plate where the throw-out bearing will be, to allow for an easy dismantling without components jumping in your face.
The following picture is an overall view, showing where the previous picture was taken
Some comments:
Personally, I will not have a problem trying to make the Ford clutch disk work. A couple of members have done it, and one has even used a Ford pressure plate in addition (member Pancho that doesn't have a Patrol anymore). Neither of the members have post anything regarding the process, other than they were able to use it. If the disk starts rubbing on the cover, the clutch won't disengage properly and you'll start eating the synchro rings. But, little by little it will rub less and less. :twisted:
There might be a way of shaving 1/16" of the the disk or even less, that will reduce its diameter to 10 7/8". Maybe placing the clutch in a lathe. All these ideas will work if you have a lathe. I don't think anybody will do that job, and the cost of it will defy the purpose.
As member faux40 has suggested, sending the disk for a rebuild might be a reasonable option.
Postby RiverPatrol » Mon Feb 20, 2023 11:10 am
Great info Esteban! :clap:
Images: 959
Has thanked: 6807 times
Been thanked: 2297 times
