Fuel Pump
Original and compatible parts
Postby Esteban » Wed May 15, 2013 8:21 pm
This is for the P40 engine, that's exactly the same.
Part #: 17010-L6200
copy the part # into the search field here:
http://www.forkliftpartssupply.com/home.aspx?Page=Parts
$130 (May-2013)
Has thanked: 2869 times
Been thanked: 888 times
Postby bosque » Wed May 15, 2013 11:03 pm
Esteban wrote:This is for the P40 engine, that's exactly the same.
Part #: 17010-L6200
$130 (May-2013)
Dude!......Maestro!......... :clap:
bosque Offline
Images: 62
Has thanked: 311 times
Been thanked: 175 times
Postby norville » Thu May 16, 2013 5:52 am
Great Job Esteban, any chance if you found out about a rebuild kit? I see they have a bunch a "gaskets" listed but no pics..
(insert clever saying here)
norville Offline
Images: 36
Has thanked: 57 times
Been thanked: 18 times
Postby Esteban » Thu May 16, 2013 8:30 am
norville wrote:...any chance if you found out about a rebuild kit? ...
I have no idea. I had the link above saved from a few years ago, that somebody posted on the internet.
Although all the fuel pumps made over the years are exactly the same on the outside, the diaphragm leg changed in two or three slightly different lengths (probably under the advice of the accountants) so they are not interchangeable.
I had a diaphragm from the early 70s and it fit perfectly on a pump that came from a 1983 P40 engine.
Postby norville » Thu May 16, 2013 8:36 am
good to know , that's the part that most rebuilds need..
norville Offline
Images: 36
Postby RMP&O » Thu Apr 30, 2015 12:35 pm
OEM available from Nissan, part # is 17010-C6028
http://www.amayama.com/search?q=17010-C6028
Other part numbers that work are,
17010-C6086
17010-C8025
Cheers
RMP&O Offline
Images: 80
Has thanked: 181 times
Been thanked: 173 times
Postby miller » Thu Apr 30, 2015 5:24 pm
RMP&O wrote:OEM available from Nissan, part # is 17010-C6028
17010-C6086
17010-C8025
Cheers
Great info. Cheers Ian!
miller Offline
Images: 95
Has thanked: 84 times
Been thanked: 325 times
