Glass Tail Lights lens
Original and compatible parts
Has thanked: 7 times
Been thanked: 29 times
Post by Sierra Patrol »
Well I SCREWED up BIG time.....
Working on the patrol Today, and did the scramble of my life as I fumbled a tail light lens and ended up after 10 times trying to catch the lens ended up dropping it into a ton of broken pieces. :angry-banghead: :angry-banghead: :crying-yellow: :crying-yellow: :crying-yellow: :crying-yellow: :crying-yellow:
So I need one, can I even buy them.....So pissed right now.
Re: Glass Tail Lights lens
Has thanked: 7703 times
That is precisely why they are so rare. ;) Always, always, always, set a big ol' blanket or comforter or pillow underneath your work area before attempting to remove a glass lens. I have broken at least a couple of them myself and yes I know exactly how you feel right now. Your knee is dislocated from kicking yourself.
Save the reflector part, you might need it. I have to go out to my shed in a little while to check on my pregnant kitty, so I will check my inventory of glass lenses. I seem to recall that I have one that doesn't have the reflector in it. *fingers crossed*
Okay, everyone start laughing but until you replace it epoxy ir together and buff flat the squeezed out glue.
SP, stop rolling your eyes at me :roll: ....if you dont do this the Patrol gods will fill up your new cross member with mud. :roll: :D
Has thanked: 195 times
Been thanked: 54 times
Post by miksum56 »
Hey, what was the final answer to your tailite lens problem!
Post by miksum56 »
Hey, did River hook you up? Use glue? Just wondering... :think:
Have not done anything yet, River does have one. I did find all the pieces not sure if I should try to glue it our not, I guess it would not hurt.
Has thanked: 54 times
Been thanked: 17 times
Post by norville »
I've used pontiac "hot rod" round lenses. I have not tried to swap the glass, I used the whole light. The big downfall is the wires are not in a waterproof seal. So if you have the old ones I'm sure you can make it work.
http://www.speedwaymotors.com/1950-Pont ... ,3079.html
(insert clever saying here)
Has thanked: 69 times
Been thanked: 84 times
Post by Urban60 »
[quote="norville"]I've used pontiac "hot rod" round lenses. I have not tried to swap the glass, I used the whole light. The big downfall is the wires are not in a waterproof seal. So if you have the old ones I'm sure you can make it work.
There are some hot rod ones that are a little smaller than the Pontiac which is 4.25" The baby hot rod ones are 3 5/8" and you don't have to make a larger hole. You do have to drill two holes for the studs to hold them on.
http://www.ebay.com/itm/140838854193?it ... album]1619[/album]
Audrey
Post by Urban60 »
These lights work for the front with only modifying the stud holes some. They have glass lenses and are 3 3/4" diameter closer to the stock size. 1947- 1948 Ford park lights, 1942 - 1947 Ford truck / hot rod lights
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... ink:top:en
1620
Audrey
