1969 Patrol Parts and information needed
Perry, Milemarker makes new ones They are around $84.00 they are 6 bolt 10 spline. I bought a set for my 67 and they bolt right on. Vern
Here is some info from the "compatible parts" list. Hubs - Locking 1969-1979? Superwinch Hub # 400507 Ser.Kit # 404401 $100.00 http://www.superwinch.com My 69 has a set of Warn locking hubs. Can't remember, but some where on this site is a discussion with the #s for the Warn hubs. Also there is a disscusion about the half doors but I can't find it either. Are you looking for a rear gasket or oil seal for the transmission? Or transfer? I can look the # up if you describe which you need. Keith
Mile marker bought the right to to selectro matic hubs for the patrol. Part # is 11009-02 Selectro supreme Mile Marker 954.782.0604
- Been thanked: 1 time
Depends on which rear tranny seal you are talking about... There is a seal between the tranny and the t-case. I presume that is the one you are asking about. It can be time consuming if you do not know all the little tips of removing the t-case. There are no lockers that I am aware of for the Patrol. I went with FJ-40 axles in 2 of my Patrols which have numerous lockers available. Then the vehicle is not stock of course. But it would not be with a locker anyways. To my knowledge there were no 1/2 doors for the later model Patrols. I could be wrong though... jeepcj_6@yahoo.com -Jeff
