Alternative fuel gauge & sender setup on my 1967.
Postby Sconnierider » Tue Feb 13, 2024 8:24 pm
This is my solution for the totally roached fuel sending unit in my heavily varnished fuel tank.
https://youtu.be/kQRmDoAns3Y
This is a link to the Amazon purchase.
https://www.amazon.com/dp/B0BQ3SD66R?re ... tails&th=1
You order these in various lengths to accommodate your specific application. I ordered mine a bit shorter than I should have (ordered 8", should have gotten 9") Upside is that I have a healthy reserve!
Sconnierider Offline
Has thanked: 1 time
Been thanked: 45 times
Postby Esteban » Tue Feb 13, 2024 9:30 pm
I like your setup. Clean and creative. Switch included. Congratulations. Nice video as well.
I would have installed on the vertical panel of the seat box facing the door, so as soon as you open the door you could activate the gauge.
Has thanked: 5589 times
Been thanked: 1441 times
Postby Sconnierider » Tue Feb 13, 2024 9:39 pm
I looked at that face as well but ruled it out given my ability to hit things, delicate things, with my size 12 boots…. :roll:
Has thanked: 1 time
Postby L60Boerne » Wed Feb 14, 2024 8:38 am
I agree with Esteban, it works and doesn't change the classic dash.
Food for file. I've driven all my Patrols dawn to dusk at 5-15 MPH and never used more than 10 gallons. I have one fuel gauge that works. It is on my white 63, RiverPatrol sold me her last OEM temperature sending unit.
Now, please apply your expertise to find a motor temperature sending unit replacement. That is an important gauge and I've bought every "alternative" our board digs up but I haven't been able to make any of them work. The alternate/modern sending units are shorter (25% -+ shorter) in length than the OEM sending units, though they fit the thread pattern and screw in properly.
But then again as River Patrol told me, "if the OEM brass radiator is rebuilt and working properly it is almost impossible to overhead the motor". That has also been my case as crawling all day while hunting from the Patrols is considered sever duty.
Rolling and Patrolling,
L60Boerne Offline
Been thanked: 1718 times
Postby L60Boerne » Wed Feb 14, 2024 8:49 am
Well, today I found a water temp sending unit that "looks" like it may work at www.finditparts.com part # 25080-89900, though it lacks threads but the length looks right. I bought four, if it works I'll report back. I give it less that 50% chance but maybe Eddie can make it work.
L60Boerne Offline
Postby Dixonsix » Wed Feb 14, 2024 2:01 pm
I see a threaded version on the same website. Using almost the same part number: NISSAN 25080-89900N
Shows it is a Helmar product
Dixonsix Offline
Has thanked: 1 time
Been thanked: 85 times
Postby Dixonsix » Wed Feb 14, 2024 2:12 pm
Dixonsix Offline
Has thanked: 1 time
Postby Sconnierider » Wed Feb 14, 2024 7:50 pm
Where in the world is this located? I poked around today before my trouble like puked out on me.
CHECK THAT QUESTION ABOVE. I found the sensor. No wire attached to it and mine has a tiny brass screw in the center to attach the wire.
Has thanked: 1 time
Postby L60Boerne » Thu Feb 15, 2024 1:19 pm
I'll ask Eddie if he can drill a hole in the end and find a brass screw that fits.
L60Boerne Offline
Return to Projects
