Frustrating day working on the Patrol.
Adjusted the brakes, and my brother helped me bleed them again (he is a really good pedal pumper with great communication). We have a pedal, but it's about halfway to the floor. Can't really figure out why. Under the Patrol while he was pumping the pedal, I could hear and feel each cylinder actuating. Got good flow out of the bleeders.
If you remember, this is stock brakes with new wheel cylinders, the original shoes with plenty of meat left, all new brake lines, and a Wilwood 1" dual master cylinder. I had already bleed these at length, but had the adjusters backed all the way off per the shop manual -- had never bled brakes that way, but figured what the heck I'll try it. Got lots of flow while bleeding and got air out, but never really had much of a pedal. So today I was hopeful that once the shoes where adjusted, I'd have a good pedal. But no joy.................
It's been 40 years since I drove this Patrol, so I sure can't remember what the pedal felt like.
But surely it should have more than just halfway to the floor. My brother suggested maybe I didn't adjust the shoes tight enough, but did exactly what the shop manual says -- tighten the adjuster until you hear it start to touch the drum, and back off slightly. Of course, this is a judgment call.......you may here it just lightly touch in one place while turning the wheel, but I usually don't use this as the point I back off the adjuster. I tighten until I hear it scrubbing pretty much all the way around and then back off until the scrubbing mostly goes away.
I'm still rolling this around in my head. I don't want to lay the blame right now on the master cylinder, but what it feels like is the circuit to the front brakes isn't building much pressure, but the rear circuit is. Kinda like if you had a leak in the circuit to the front brakes, and only the rears are applying. I know the front cylinders are moving some because I can feel them and hear them when the pedal is pumped, but don't have a way to tell how much pressure is being built up. I did not drive the Patrol this trip, because I forgot to bring the battery, but next trip I'll drive it some down the dirt road next to my Mom's house.
I'll keep rolling this around in my head, but sure would welcome opinions and advice from others, especially those who have used the Wilwood dual master cylinder.
