Has thanked: 19 times
Been thanked: 15 times
Post by Avpatrol »
So what have i done this week yo my patrol?hhmm.
Well, i took apart the thermostat housing,water pump and radiator to give them an overnight shower of good old vinegar to get rid of all the accumulated rust from all these years od sitting(btw,vinegar does miracles to these parts,i even filled the radiator with tw0 gallons of vinegar and it worked magic),drained all the oil off the engine,took off the valve cover to see all the gunk and get it ready for a flush.although it doesn't look to bad considering how old this poor thing is,i sanded off the old oaint and rust from the oil filter cannister and gave it a fresh coat of paint.i also received a few parts that i ordered online such as the power break booster,thermostat and all four shocks from gabriel shocks.
I masked the booster to paint the cylinder before installing it. And i think thats all for this week.
My plans for this weekend is to remove all the suspension components to clean them up and change all the bushings, also will bring the gas tank off and wash all the nastiness inside off.
Man is so fun working on these beauties.
Sugestions and advice is welcome.
Has thanked: 6028 times
Been thanked: 1608 times
Great progress. Congratulations! :clap: :clap: :clap:
Your water pump looks in very good condition, and the paint job done is looking great.
Did you test how good will that paint withstand the brake fluid? I was looking the other day and Eastwood only has a gray color. I would like to paint the same as yours.
Post by Avpatrol »
Thanks.and as far as the paint,i used ceramic heat resistant paint but i did not check if it resist break fluid.
I will have to research it.thanks for noticing that :shock:
Has thanked: 7743 times
Been thanked: 2482 times
Esteban beat me to it - I was thinking the water pump looked to be in good shape as well. The thermostat housing also looks good, sometimes they are rotted out.
Post by Avpatrol »
Same thing in my mind when i took it apart,
The water pump seems to be in good shape,there no play in the shaft .i was thinking on trying to have it rebuild but it really feels solid.
Question, is that hole at the bottom of the water pump back plate a drip hole or is just a rotted out hole that i have to seal?
Avpatrol wrote:Question, is that hole at the bottom of the water pump back plate a drip hole or is just a rotted out hole that i have to seal?
That hole is correct. Never quite understood its function. Probably aids in draining all the water from the system when opening the petcocks.
Fill the system with a 50/50 mix of Prestone and distilled water, or buy the pre-mixed formulation.
Has thanked: 174 times
Been thanked: 408 times
Post by mad4hws »
Today we replaced the clutch master cylinder and the slave cylinder. We purchased the set off of ebay from OEM_Alternatives. There were a couple of modifications that we had to do in order for this to work.
5332
We started with the slave cylinder. the hypothesis was that it was leaking and therefore was the culprit.
5331
The Slave cylinders (new on the bottom, old on the top)
5334
The threads were a little bit different, so i had to use a different line. In the end, I ended up going with BrakeBest BH845517, which matched up well. now i'll have to replace that before I tackle the brake job. After getting the slave cylinder installed, the brake pedal was still hitting the floorboard, so we decided to replace the master cylinder as well. Old on top, new on bottom. As soon as we removed this, we knew the master cylinder seal was the culprit. The pushrod had no resistance and came right out.
5333
We had to instal this a few times. We couldn't get the new adjustable pushrod to adjust down far enough. On the third try, were replaced it with the original after cleaning it up a bit. We also used the original fluid cylinder as it was a little taller and held a little more fluid. It worked like a charm and got the Minion Missile back on the road. Special thanks to Minion #3 (Ann)
Here she is installing the slave
5336
Here she is putting the finishing touches on the master
5337
Post by Avpatrol »
Nice,you have your lil one helping out.
Im the same way with my lil one.
Post by mad4hws »
Ya. That's most the point with this rig, a project that everyone can jump in on and participate. Its actually pretty great. The Patrol is easy enough to work on so that it works out really well. We do a little at a time so that it's not too overwhelming. The minute it starts to feel like 'work' we stop.
mad4hws wrote:Ya. That's most the point with this rig, a project that everyone can jump in on and participate. Its actually pretty great. The Patrol is easy enough to work on so that it works out really well. We do a little at a time so that it's not too overwhelming. The minute it starts to feel like 'work' we stop.
That is one of the great things about Patrols - that they are so easy to work on. It allows a novice mechanic type to get in and fix things and feel confident about it. It's always fun to see someone make a family project out of it.
