2869ral wrote:Hi Andrew these are supposed to take leaded fuel, you can run it without, but the lead actually lubricates the valves. I reccomend using the lead additive whenever possible. I believe the carb is a single barrel rochester, kits are available at any parts store. To double check look right under the choke linkage on the top piece of your carb. It will say rochester there if it is. Also your original mechanical fuel pump would be on the left side of the block just above the oil pan between the motor mount and the oil filter. If you have an eletrical pump, there is probably a blockoff plate there now. The reason for mounting an electric fuel pump closer to the fuel tank is to pressurize as much of the fuel line as possible. This raises the boiling point of the fuel in the line. If you are not having a problem with vapor lock, i wouldnt move it. HOpe this helps.
See, i toldja ron was the man... he knows his stuff!
